Hello
Guest
it is
November 13, 2026, 03:26:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Tangential control +-360 degrees
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Tangential control +-360 degrees (Read 10156 times)
JiiPee
5
on:
October 14, 2013, 05:52:03 AM »
Hello
I use tangential control but I have wires and pneumatics going to rotate axis.
I use 2.5D cam and I cant´t get A axis values.
Problem is that tangential control is turning too much. Wires and pneumatics is rotating to axis.
Is there any possibility to program tangential control so that it is not rotating over 360 in same direction?
Logged
Sirius
3
Re: Tangential control +-360 degrees
Reply #1 on:
September 23, 2014, 06:15:49 PM »
I am needing to implement this same feature to limit rotation, did you find a way to do this?
Logged
JiiPee
5
Reply #2 on:
September 24, 2014, 02:09:55 AM »
We assembled pneumatics and heating element wires so that over 720 degrees turning is possible.
Way to do this, is buy good enough CAM-software where you can limit rotating axis.
Last Edit: September 24, 2014, 02:13:35 AM by JiiPee
Logged
Sirius
3
Reply #3 on:
September 25, 2014, 01:47:54 AM »
Thanks for the reply, even though it wasn't what I wanted to hear.
I was hoping there was a tick box that I just hadn't found yet that said "Limit Rotation to 360deg"
Oh well, looks like a wish list item to be submitted.
Cheers!
Logged
Print
Pages:
1
Go Up
« previous
next »
