Hello Guest it is November 13, 2026, 03:48:35 PM
Author Topic: 5th axis set up  (Read 11917 times)
Offline comet
  •  338 338
5th axis set up
« on: October 10, 2013, 03:29:52 AM »
   I am looking at setting up a 5th axis (table type) but cant find any info on setting the axis planes in mach.
whats happening is that when I program in my cam software the emulation looks perfect but when I import the G code into mach it looks weird,so im wondering whats going wrong?
  Tony
Offline comet
  •  338 338
Re: 5th axis set up
« Reply #1 on: October 11, 2013, 04:25:20 AM »
from what I can tell Mach wont run more than 3 axis in the graphics window although the code should be correct assuming the machine parameters were set up in the cam package?, i.e. a revolving on x axis and b on y and assuming the +- is correct ?
   Does anyone know why the fanuk post ,produces code that skips a and uses b&c instead,is that so a axis is always differant from a trunnion setup?
Re: 5th axis set up
« Reply #2 on: October 11, 2013, 04:56:15 AM »
As far as I remember Mach can display X, Y, Z and A but not B or C.
Offline comet
  •  338 338
Re: 5th axis set up
« Reply #3 on: October 17, 2013, 12:41:16 PM »
well I guess from the lack of advice, answers practically no one is running mach on 5 axis!
Re: 5th axis set up
« Reply #4 on: October 17, 2013, 07:55:47 PM »
The posts are developed to run the machine AS it is setup.  The normal abc designation is for the A to run parrallel to X and B to Y and C to Z on a normal setup as rotary axis's.
Mach3 not having WORLD jogging makes it tough to run 5/6 axis code .
Just a thought, (;-) TP
Offline comet
  •  338 338
Re: 5th axis set up
« Reply #5 on: October 18, 2013, 02:36:27 AM »
"Mach3 not having WORLD jogging makes it tough to run 5/6 axis code"
what does that mean?
 Tony
