Hello Guest it is November 10, 2026, 02:45:05 AM
Author Topic: M8 Flood output not working  (Read 8155 times)
« on: October 06, 2013, 10:20:16 PM »
hey all,
I am setting up a flood output and M8 does not turn on the output.  I am using output 5 port 1.
The output works when I use the "output tab" under "Ports and Pins".  I test this by setting Output#1 to enable and use on port 1 pin 5.  Then I select active high then active low and the output toggles. I then turn this output off and go to the "Spindle setup" and enable "flood mist control" and set my output to pin 5.
I have tested the output two different ways.  1) I go to the diagnostic page and toggle flood and nothing happens. 2) run code with a M8 and it does not turn on.  Also,  When I restart the PC the output it on which is odd but I can live with that.
I think I do not have to setup an output since the manual states it is automatic. Also,  all other outputs run fine, XYZ and spindle.
What am I missing?
Phill D.
Re: M8 Flood output not working
« Reply #1 on: October 06, 2013, 11:56:32 PM »
Figured it out.  under M8 is states output # and I was thinking pin #
