Mach Discussion => General Mach Discussion => Topic started by: ped8015 on October 06, 2013, 11:20:16 PM
hey all,
I am setting up a flood output and M8 does not turn on the output. I am using output 5 port 1.
The output works when I use the "output tab" under "Ports and Pins". I test this by setting Output#1 to enable and use on port 1 pin 5. Then I select active high then active low and the output toggles. I then turn this output off and go to the "Spindle setup" and enable "flood mist control" and set my output to pin 5.
I have tested the output two different ways. 1) I go to the diagnostic page and toggle flood and nothing happens. 2) run code with a M8 and it does not turn on. Also, When I restart the PC the output it on which is odd but I can live with that.
I think I do not have to setup an output since the manual states it is automatic. Also, all other outputs run fine, XYZ and spindle.
What am I missing?
Phill D.
Figured it out. under M8 is states output # and I was thinking pin #
