Hello Guest it is October 21, 2026, 01:01:42 PM
Author Topic: mach3 stops responding while running programs  (Read 26563 times)
« on: September 24, 2013, 03:01:06 PM »
Just tried cutting some programs and every time Mach 3 stops and the computer says not responding and I have to shut it down and unplug the smoothstepper and then plug it back in,restart Mach and same thing happens any ideas
Re: mach3 stops responding while running programs
« Reply #1 on: September 24, 2013, 03:44:02 PM »
Sounds like the SS is losing communication and Mach is just hanging waiting for communications.
Is it a USB SS or Ethernet?
« Reply #2 on: September 24, 2013, 03:57:13 PM »
I have the usbss
« Reply #3 on: September 24, 2013, 06:11:17 PM »
Sounds like your USB ports may be set to save power.  Read here how to set to always on: http://www.ehow.com/how_6791680_disable-power-management-windows-xp.html
John Champlain
« Reply #4 on: September 24, 2013, 09:07:33 PM »
Will try tomorrow
« Reply #5 on: September 25, 2013, 03:05:23 PM »
Fixed the usb setting ran machine 4.5 minutes and it quit again,I noticed that one of the lights on the smoothstepper were out
« Reply #6 on: September 25, 2013, 04:34:07 PM »
I think you may be having problems with the USB SS losing communication for some reason. It could be related to the problems others saw due to noise, in fact I saw this on one machine and the cure for it was to remove a couple of components on the SmoothStepper to isolate the Gnd connection of the SS from the Computer. I think you can do the same by cutting through the shield of the USB cable at the SS end of it.
I will see if I can find the thread regarding this issue and paste in a link in a minute.
« Reply #7 on: September 25, 2013, 04:36:27 PM »
« Reply #8 on: September 26, 2013, 03:04:07 AM »
I will try that today if that does not work I will find another computer without 64 bit and trash the ss,I am getting pretty frustrated
« Reply #9 on: September 26, 2013, 01:34:16 PM »
I ran a program without the motors being plugged in and it ran all the way through
