Hello Guest it is October 25, 2026, 12:29:47 AM
Author Topic: spindle relay  (Read 8440 times)
spindle relay
« on: September 22, 2013, 12:52:54 AM »
I have a cnc router that I control with mach3.  While trying to figure out my pins and ports I must have turned off the signal to the relay that turns on the power to the spindle.  I can't seem to figure out what I did or how to fix it.  Any thoughts?
Thanks  Bob
Re: spindle relay
« Reply #1 on: September 22, 2013, 01:45:37 AM »
You need to have Disable Spindle Relays unchecked and also have the correct port and pin number set up for whichever output you have set for Spindle relays.
Both can be accessed from Config menu, Ports and Pins.  The Spindle relays will be found on Spindle Setup page and the actual output you want will be found on OutPut Signals page.
Re: spindle relay
« Reply #2 on: September 22, 2013, 03:10:58 PM »
Thank You  It's now working properly.
Bob
