Mach Discussion => General Mach Discussion => Topic started by: bobhallinan on September 22, 2013, 01:52:54 AM
I have a cnc router that I control with mach3. While trying to figure out my pins and ports I must have turned off the signal to the relay that turns on the power to the spindle. I can't seem to figure out what I did or how to fix it. Any thoughts?
Thanks Bob
You need to have Disable Spindle Relays unchecked and also have the correct port and pin number set up for whichever output you have set for Spindle relays.
Both can be accessed from Config menu, Ports and Pins. The Spindle relays will be found on Spindle Setup page and the actual output you want will be found on OutPut Signals page.
Thank You It's now working properly.
Bob
