Hello Guest it is September 06, 2026, 02:34:27 AM
Author Topic: Y axis won't move in Job Step but work fine in Continous Mode?  (Read 32007 times)
« on: September 19, 2013, 02:24:33 AM »
My X and Z axises work fine in both Jog Step or Continous mode even at small increments. My Y axis is setup teh excat same way (i think). But the problem is that as soon as i switch the Jog Mode to Step Mode the Y axis won't move at all. X and Y moves fine. As soon as i switch back to Continous Mode again. All axises move fine again?
Makes no sense to me?
Re: Y axis won't move in Job Step but work fine in Continous Mode?
« Reply #1 on: September 19, 2013, 12:11:26 PM »
Attach your xml please and I will have a look.
« Reply #2 on: September 19, 2013, 12:25:09 PM »
Thanx you SOOOOO much man. Im so stuck! Excuse my ignorance but the xml file is?
« Reply #3 on: September 19, 2013, 12:26:03 PM »
The pref file that launches mach3?
« Reply #4 on: September 19, 2013, 12:31:35 PM »
Open Mach and look lower right at the name of the profile.
Close Mach then go to the Mach3 folder on you r hard drive and look for a file of that name with a .xml file extension.
Copy it to your desktop and rename to something unique, something like andros.xml
Use the additional options button on the reply page to browse to your desktop and choose the renamed file.
« Reply #5 on: September 19, 2013, 12:42:36 PM »
Thank you. Will send it to you tomorrow. Im desperate so i will look for you email every second. I reallllly appreciate you taking the time to help me!
« Reply #6 on: September 20, 2013, 02:11:46 PM »
Hey Hood!
Here is a video I recorded of the super weird problem I have:
http://www.youtube.com/watch?v=GWKeM4iC-Pw
Attached is the XML
Looking forward to your answer
« Reply #7 on: September 20, 2013, 03:24:15 PM »
Hi Andros, it seems to be working fine here in simulation so I am unsure why it is a problem for you.
Can you tell me, does the Y axis DRO show that it is moving? It does here.
I do notice there are no HotKeys set up for your axes, I am not sure if that will make any difference as it seems fine here but it may be worth trying to set them up anyway. To do that go to Config menu then System Hotkeys. Click on X++ and a box will pop up asking for you to press a key, click you right arrow. Next X-- and press Left arrow, move to Y++ etc and do them all.
« Reply #8 on: September 20, 2013, 03:24:28 PM »
Did you try step jog from the popout screen instead of the keyboard . Or how about from the NUM keypads, Turn off numlock.
Just a thought, (;-)Tp
« Reply #9 on: September 20, 2013, 04:17:11 PM »
yes. no difference unfortunately.
