Hello
Guest
it is
October 20, 2026, 09:01:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
SUB programs
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: SUB programs (Read 8764 times)
BR549
6,965
SUB programs
on:
September 10, 2013, 07:17:19 PM »
OK the subs for circular pockets and Square Pockets are done. Both are programmable as to size and depth AND conv or climb milling. The square is also rotatable.
Working on the tapping sub now.
Does anyone have a procees they we need to make into a SUB. These can be called from inside a gcode program OR called from the MDI by the use of a SubLoader Mcode
BR549
6,965
Re: SUB programs
Reply #1 on:
September 13, 2013, 10:20:57 PM »
OK I have the Bolt Circle SUB completed. It has 3 functions , Spot Drill, Drill, Tap. You can turn each ON or OFF.
The Bolt Circle parameters are completely programable from Gcode. You define what you need and IT does it.
(;-)TP
BR549
6,965
Re: SUB programs
Reply #2 on:
September 13, 2013, 10:45:13 PM »
I also have the"Ball in Cube" program just about done. This one was FUN to do.
Print
Pages:
1
Go Up
« previous
next »
