Hello
Guest
it is
November 26, 2026, 03:51:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
SUB programs
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: SUB programs (Read 9074 times)
BR549
6,965
SUB programs
on:
September 10, 2013, 07:17:19 PM »
OK the subs for circular pockets and Square Pockets are done. Both are programmable as to size and depth AND conv or climb milling. The square is also rotatable.
Working on the tapping sub now.
Does anyone have a procees they we need to make into a SUB. These can be called from inside a gcode program OR called from the MDI by the use of a SubLoader Mcode
Logged
BR549
6,965
Re: SUB programs
Reply #1 on:
September 13, 2013, 10:20:57 PM »
OK I have the Bolt Circle SUB completed. It has 3 functions , Spot Drill, Drill, Tap. You can turn each ON or OFF.
The Bolt Circle parameters are completely programable from Gcode. You define what you need and IT does it.
(;-)TP
Logged
BR549
6,965
Re: SUB programs
Reply #2 on:
September 13, 2013, 10:45:13 PM »
I also have the"Ball in Cube" program just about done. This one was FUN to do.
Logged
Print
Pages:
1
Go Up
« previous
next »
