Hello Guest it is November 23, 2026, 07:15:09 PM
Author Topic: 1 X Axis Stops  (Read 9396 times)
1 X Axis Stops
« on: September 09, 2013, 08:40:32 PM »
I am testing a 4 axis system from Mike Beck (Hobby CNC Controller). Using Mach 3 from 2006 and when I go from Tool Path to Program Run one of the X axis motors stop & the other keeps running. The motors are 305 oz. This would be a problem if It was on my machine. Is this a known Problem or could it be my motors or controller ?
Another question, I am building a 4' X 3' machine. What size motors should I use if I plan to cut Aluminum ?
Re: 1 X Axis Stops
« Reply #1 on: September 10, 2013, 04:39:55 AM »
Suggest you have a look at machines similar to what you are building.  Post back when  you have more specifics.
