Hello Guest it is October 21, 2026, 03:14:39 AM
Author Topic: question on weight  (Read 20790 times)
Offline dude1
  •  1,253 1,253
question on weight
« on: September 08, 2013, 04:59:10 PM »
need some help working out weight of a gantry to convert it to kgf-cm or kgf-m to N m.
the gantry weight is about 200 kg.
do i just do 200kg-m to Nm or is it 200kg-cm to Nm.
i know how to convert one to the other im not sure if i use 200kg-cm or 200kg-m to work out the conversion from 200kg to Nm
Re: question on weight
« Reply #1 on: September 09, 2013, 05:54:20 AM »
daniellyall,
1 kgf-m = 9.80665 N-m
The above conversion is for force at a distance from some point which is a TORQUE value. A N-m is used to provide
motor info....usualy.
You don't have a turning force from the weight until you calculate the force required to just move the weight along
a path. That force, refined .....based on gearing, friction factor and screw / gear / belt influence,  times the offset distance to the driving
axis will give you a torque value.
« Last Edit: September 09, 2013, 05:55:52 AM by RICH »
Offline dude1
  •  1,253 1,253
« Reply #2 on: September 10, 2013, 04:33:01 PM »
the nuts and bolts of it is, pin pully 90 tooth, stepper pully 18 tooth, the rack pitch is 3.78 the pin is 23 tooth the axis can move 2.4m. i cant under stand the formullars for working out the required forces, im bad at math
« Reply #3 on: September 11, 2013, 04:54:53 AM »
Most of the major motor / rail / screw suppliers provide sizing software on their web sites to do the calculations for you based on supplied information of your sysytem. Do a search and try some of them as they all do the same but the input interfaces are different. The result
can be used as a guide for intial selecton of components. I say guide because it provides a theoretical value and one still needs to
use some common sense on how conservative they want to be on sizing.
There is a practical way.
Once you build your system, ADJUST / LUBRICATE IT,  but before you purchase motors, find the the torque to just move the axis by measuring it. Just use a torque wrench (or an equivilant like hung weights) to find the value. Then double or triple the value.  Be consrvative
as this allows for acceleration at higher motor rpm values ( remember that a steppers torque decreases as rpm increases ) and a servo is sized differently.
There is nothing wrong with comparing equivilant size equipment to get a quick ballpark figure. But do make note of YOUR desired
operating conditions.
Designing a system can get complex quickly and one needs to understand what they are doing.
So, you intial question is a loaded one, and hope replied information helps you out.
Offline dude1
  •  1,253 1,253
« Reply #4 on: September 11, 2013, 05:45:19 PM »
i have been trying to work it out its on r an p i am have trouble working out the pitch of the rack i counted 50 tooth it was 189 mm long, when i work it out its wrong i used a ball screw calculator and worked out the pitch is 300 to get the same steps/per as what the machine is out putting when it is calibrated.
if some one has a good formular to work it out help.
i have attached a copy of the step cala i used to work it out.
« Last Edit: September 11, 2013, 06:04:41 PM by daniellyall »
Offline dude1
  •  1,253 1,253
« Reply #5 on: September 11, 2013, 06:15:38 PM »
its wrong its a pitch of 40 to get it correct i checked it of against the axis that i have with a ball screw so 40 is correct for pitch
Offline dude1
  •  1,253 1,253
« Reply #6 on: September 11, 2013, 06:41:45 PM »
this is correct this time had someone else look at it  :-[
thanks rick i have just finished doing that it works out that the stepper is doing 187 rpm it should easly do 2400mm/min but only can do 800mm/min max in acurucy going faster than 800mm/min its just *********. had a look at the torque vs speed chart it shows the motor this machine has will be running at about 500 oz-in  not the 800oz-in it is ment to be out putting thats useing a stepper calcalator that works out the rpm as well as steps/per this version is correct can someone check please. if its correct going by the weight of the gantry running a 1288oz-in stepper motor at 72v it should out put around 900 oz-in what should work fine if all calcatlations are correct.
« Last Edit: September 11, 2013, 06:49:06 PM by daniellyall »
« Reply #7 on: September 11, 2013, 09:02:53 PM »
What you need to calculate for is the torque required to accellerate the mass at the level you require. It is an inertial calculation.
Just a thought, (;-) TP
Offline dude1
  •  1,253 1,253
« Reply #8 on: September 11, 2013, 09:04:14 PM »
how cant find info i this i can understand
« Reply #9 on: September 12, 2013, 05:30:30 AM »
Attach the motor curve you are using.
