Hello Guest it is November 23, 2026, 11:15:47 PM
Author Topic: Motor tuning  (Read 11514 times)
Motor tuning
« on: August 31, 2013, 01:08:22 PM »
Im curious do some of you have your XY axis set differently then your Z.
My X and Y  I can set allot higher than my Z . If I try setting my Z as high as the others Z falls on its face. But im worried in a maching oppeation x & y will lose steps if I set them hat high.
Re: Motor tuning
« Reply #1 on: August 31, 2013, 01:23:04 PM »
As far as Mach is concerned you can have the motor tuning for each axis different.
Re: Motor tuning
« Reply #2 on: August 31, 2013, 01:48:15 PM »
Hood,
Will setting axes differently have a negative effect on CV mode and/or feed rate?
John Champlain
Re: Motor tuning
« Reply #3 on: August 31, 2013, 03:08:28 PM »
All three my steppers diver and power supply is the same.
I understand I can have different motor settings and lets say I set Z low and XY up higher. If my Z is falling on its face because it has more of a load will X and Y do the same when they have a larger load on them when its time to cut a piece?
Re: Motor tuning
« Reply #4 on: August 31, 2013, 04:04:32 PM »
John,
 shouldnt do although there were reports with the Z being considerably slower than the X and Y and doing 3 axes simultaneous moves that the Z could stall, cant remember the exact details but it was if I recall only if the Z was really slow compared to the others.
mrich0908
Its possible but that is why with steppers you should find your max then back off 10 or so percent.
Re: Motor tuning
« Reply #5 on: September 09, 2013, 07:25:43 AM »
Great post very interesting.
