Hello Guest it is October 21, 2026, 12:07:34 PM
Author Topic: Binding when homing at 100% speed  (Read 9057 times)
« on: August 28, 2013, 05:47:36 AM »
since I set up my mill I have this problem that X,Y and Z axis will bind when going for reference at speeds higher then 40% of max speed.
I do not have problems with max speed (1200mm/min) and acc (700mm/sec^2) when jogging on the BF20L, but when homing this problem occurs.
Is there a solution to this?
Thanks!
Re: Binding when homing at 100% speed
« Reply #1 on: August 28, 2013, 12:20:02 PM »
Can you attach your xml please.
« Reply #2 on: August 28, 2013, 12:49:50 PM »
sure
« Last Edit: August 28, 2013, 12:53:29 PM by Don Momo »
