Hello Guest it is November 07, 2026, 02:14:02 AM
Author Topic: Correct way to do this?  (Read 20831 times)
« on: August 27, 2013, 10:48:07 PM »
Any help appreciated I am brand new & have no idea how to do this, I am using MachScreen.
I want to have 1 button to control the PluginCameraV2.12 e.g push once = camera on, push again to turn camera off. I also want to get my warmup spindle work correctly the only way I could manage was to do a load file for a Gcode file I created.
I believe the only stupid question
is the one I didn't ask!
Re: Correct way to do this?
« Reply #1 on: August 29, 2013, 02:33:53 AM »
Hi
for your LED toggle issue you could use the following script:
If GetUserLED(1000) Then
SetUserLED(1000,0)
Else
SetUserLED(1000,1)
end if
don't forget to set the "Macro control on" checkmark and the "LED number for camera on / off" values in the camera plugin CONFIG Dialog.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: August 29, 2013, 06:12:10 AM »
Thank you Klaus I will try this
