Hello Guest it is October 21, 2026, 02:52:18 PM
Author Topic: Installing new motors  (Read 7715 times)
« on: August 19, 2013, 05:50:01 PM »
I presently have 3 nema 23, 130 oz motors that I will be replacing with nema 23, 425oz. My question is do I need to re-calibrate my new motors, I'm running Mach3 with hobbycnc pro board.?
Any help in calibration values to input would be appreciated as a starting point  ;)
Re: Installing new motors
« Reply #1 on: August 19, 2013, 08:54:17 PM »
You should just need to change the velocity and acceleration settings. If you don't change those, then you won't see any difference with the new motors.
