Hello Guest it is October 21, 2026, 04:44:39 PM
Author Topic: spindle speed rev counting  (Read 10502 times)
« on: August 19, 2013, 06:48:59 AM »
hi to all
i have retrofitted my 'denford starmill'
the spindle is fitted with a proximity detector that i want to use so that i can be aware of the spindle speed. i an a retired engineer with many many years of cnc production, BUT very little electricaal knowledge, so in very basic laymans terms would someome please talk me through what i need to do pins to use voltage required etc.
regards baz
Re: spindle speed rev counting
« Reply #1 on: August 19, 2013, 12:19:45 PM »
It will all depend on what hardware you have, such as type of breakout board, what the specs of the prox are etc.
« Reply #2 on: August 19, 2013, 12:54:35 PM »
hi i am using routout equipment, printer port breakout board, the switch does not short when metal introduced does this help?
regards
« Reply #3 on: August 20, 2013, 09:35:11 AM »
Not familiar with routout stuff, might be worth asking them if they can help. You will need to give them the part number or even better a link to the specs of the prox you will be using.
« Reply #4 on: August 20, 2013, 11:35:07 AM »
hi will do thanks for your input regards baz
