Hello Guest it is October 21, 2026, 06:12:28 AM
Author Topic: MPG2 problems  (Read 6936 times)
Offline mvoros
  •  141 141
MPG2 problems
« on: August 16, 2013, 02:24:02 PM »
Hello All,
Can someone tell me the settings for this MPG? Well it worked, sort of before I switched to a different version of mach. Had to do the configuration from a scratch. When I open the fly out virtual Mpg and try to move in the X, I get this message: No zeroing while running.  When I select the Y, than it gives this message: Nothing to feedhold. On selecting the Z and 4th, no status message. Also, if there is a G code program open, touching anything on the pendant, it starts the program, or runs away. This is maddening. Is there a newer Brain out there? I think the one I was told to use is about 10 years old.
Mike
