Hello Guest it is November 22, 2026, 08:41:19 AM
Author Topic: Mach3 and THC Up an Down doesn´t work with new USB Board  (Read 28352 times)
Re: Mach3 and THC Up an Down doesn´t work with new USB Board
« Reply #10 on: July 21, 2013, 05:43:27 AM »
You will have to contact the makers of your USB board and ask them if THC is supported.
 If it is not then you will have to ask them if they can add that functionality to the plugin for their board.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #11 on: July 21, 2013, 05:44:42 AM »
ok,
but thats means i can not use the usb card?! Sorry, me english is not so good.
I am using the proma THC from ebay.
i need 6 input signals.
x,y and Z home switch. And THC Up, down and Arc ok.
Is there a card with PP with 6 input signals? I only found 5
You don't need two inputs for x and y home switches you can wire them in series to one pin.
Ian
Offline stirling
  •  2,188 2,188
  • UK
« Reply #12 on: July 21, 2013, 05:52:31 AM »
Picky I know - but I think the THC functionality has to be in the firmware of the board not the plugin.
Ian
« Reply #13 on: July 21, 2013, 06:05:31 AM »
I didn´t thought that way.
The homeswitches are all openers.  I will try it.
Thorsten
