Mach Discussion => General Mach Discussion => Topic started by: ThorstenU on July 21, 2013, 04:04:33 AM
Title: Mach3 and THC Up an Down doesn´t work with new USB Board
Post by: ThorstenU on July 21, 2013, 04:04:33 AM
Hello,
i bought a new USB Motion Board for Mach3, so i my machine can have more Input signals.
Here you can see the card on ebay http://www.ebay.de/itm/3-axis-CNC-USB-Card-Mach3-Breakout-Board-Interface-200KHz-windows2000-xp-vista-/261163685477?pt=Motoren_Getriebe&hash=item3cce919665 (http://www.ebay.de/itm/3-axis-CNC-USB-Card-Mach3-Breakout-Board-Interface-200KHz-windows2000-xp-vista-/261163685477?pt=Motoren_Getriebe&hash=item3cce919665)
But now the z Achse does not move up and down. The light for the input signal is flashing and mach3 does say the same.
But nothing happens when the TH Up and Down signal is active.
What could be my problem. With my normal breakout board everything worked fine.
Thanks from germany
Thorsten
Title: Re: Mach3 and THC Up an Down doesn´t work with new USB Board
Post by: stirling on July 21, 2013, 04:31:44 AM
Mach's full THC capability only exists in the parallel port driver.
Ian
Post by: ThorstenU on July 21, 2013, 05:16:30 AM
ok, thats not good. How can i fix it?
Post by: stirling on July 21, 2013, 05:18:33 AM
Fix what?
Post by: ThorstenU on July 21, 2013, 05:21:12 AM
How can i use my thc control with the usb board.
Or is there no possibility?
Post by: stirling on July 21, 2013, 06:09:57 AM
I know of NO external motion card that supports THC. AFAIK it's parallel port only.
Post by: Hood on July 21, 2013, 06:24:57 AM
CSMIO and I think SmoothStepper support THC, possibly others,   but as Ian has eluded to, the THC function has to be supported by the device you are using, whether that is Parallel Port or an external controller.
 You need to talk to the maker of your USB controller and get them to add that function if it is not already supported.
Post by: stirling on July 21, 2013, 06:29:57 AM
OK Hood - thanks - I didn't know the CSMIO supported THC. I know the SS didn't used to but maybe that's changed.
@Thorsten - out of interest what THC are you using and why do you need more inputs than the PP gives you?
Ian
Post by: Hood on July 21, 2013, 06:37:38 AM
Hi Ian,
 have attached a couple of screenshots of both SS and CSMIO plugins, as you can see THC options are there in both. How well they work I have no idea as I dont use Plasma but I have heard from people that the CSMIO one works as expected.
Post by: ThorstenU on July 21, 2013, 06:40:57 AM
ok,
but thats means i can not use the usb card?! Sorry, me english is not so good.
I am using the proma THC from ebay.
i need 6 input signals.
x,y and Z home switch. And THC Up, down and Arc ok.
Is there a card with PP with 6 input signals? I only found 5
Post by: Hood on July 21, 2013, 06:43:27 AM
You will have to contact the makers of your USB board and ask them if THC is supported.
 If it is not then you will have to ask them if they can add that functionality to the plugin for their board.
Post by: stirling on July 21, 2013, 06:44:42 AM
ok,
You don't need two inputs for x and y home switches you can wire them in series to one pin.
Ian
Post by: stirling on July 21, 2013, 06:52:31 AM
Picky I know - but I think the THC functionality has to be in the firmware of the board not the plugin.
Ian
Post by: ThorstenU on July 21, 2013, 07:05:31 AM
I didn´t thought that way.
The homeswitches are all openers.  I will try it.
Thorsten
