Hello Guest it is November 22, 2026, 08:26:29 AM
Author Topic: Z zeroing issue  (Read 9317 times)
Z zeroing issue
« on: July 19, 2013, 10:50:46 PM »
Hello all, have a problem and need some expert advice.
When I run the zeroing routine on the big tex screen set I am getting a estop when the bit touches the plate. I have the pin set to 10 on port 1. This is how the machine came form the factory. In the diagnosis  screen the digitize light is light. The test light on the main screen lights up when I touch the bit to the plate but at the same time the estop trips.
Any ideas on where to start?
John
Re: Z zeroing issue
« Reply #1 on: July 20, 2013, 03:31:26 AM »
Have a look and see if your E-Stop is also set to port 1 pin 10.
Re: Z zeroing issue
« Reply #2 on: July 22, 2013, 04:47:02 PM »
Thanks Hood, that was the issue. It works perfect now.
John
