Hello Guest it is November 22, 2026, 07:07:45 AM
Author Topic: X DRO changes after running lathe drill wizard?  (Read 11451 times)
« on: July 19, 2013, 09:36:10 AM »
Peck drilled some holes last night in the lathe using the wizard downloaded from http://www.machsupport.com/forum/index.php/topic,16533.0.html  It worked well other than the X DRO would at some point display the X tool offset value of the tool in use & I noticed the change after it was finished.  I could re-type the tool number in the "Tool No." box and the X DRO would go back to +0.0000 as it should.
It freaked me out when I looked up & saw something other than +0.0000 in the DRO and I thought it had somehow re-positioned itself and could try to drill off center & crash.  Fortunately it hadn't physically changed position, just the DRO changed.  No biggie, just curious what's going on.
Milton from Tennessee ya'll.
Re: X DRO changes after running lathe drill wizard?
« Reply #1 on: July 19, 2013, 09:46:32 AM »
Would have to see the code and possibly also your xml and tool table.
Even then I may not see what is wrong ;D
« Reply #2 on: July 19, 2013, 09:54:23 AM »
Thanks for the quick response!  I'm trapped behind a desk at work right now. :'(
« Reply #3 on: July 21, 2013, 06:11:01 AM »
I suspect you have the same problem as I have - go to the General Config page and on the lower left there is a block regarding the actions after a M30. Uncheck the 'remove offsets on program end' tick box and voilá....well, worked for me anyway!
Simon
« Reply #4 on: July 21, 2013, 07:55:30 AM »
Thanks Simon, that was the problem.
Should've known anybody that could spell voilá correctly would have the answer!;D
« Reply #5 on: July 21, 2013, 04:09:22 PM »
 :D
Comes with living in France and having an AZERTY keyboard...
Glad to help someone else, usually I'm the one asking but on this occasion I hit and solved the same problem just in advance of you
Simon
