Hello Guest it is November 22, 2026, 02:47:33 PM
Author Topic: BobCAD-CAM Bore depth, limited to 2" ?  (Read 14639 times)
« on: July 19, 2013, 08:18:57 AM »
I'm having an issue when creating a rough bore toolpath. The geometry is selected 3" deep into the bore but the toolpath will only calculate to 2" deep. Any ideas?
Re: BobCAD-CAM Bore depth, limited to 2" ?
« Reply #1 on: July 19, 2013, 03:23:21 PM »
I think that is a BOB CAD/CAM problem.
« Reply #2 on: July 19, 2013, 04:05:26 PM »
 :( Bummer. It's frustrating because the finish pass toolpath computes all the way to my desired 3" but the rough does not. And I'm using the rough/finish cut selection which uses the same selected geometry. Maybe I'm switching back to FeatureCam? Is there a recommend CAM program besides FC and BobCAD which is good for ID radius work? I'm cutting the inside radius of turbo compressor housings...
« Reply #3 on: July 19, 2013, 05:32:55 PM »
You may want to ask BOBCAD WHY it does it. It should NOT.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #4 on: July 21, 2013, 12:21:04 PM »
I sounds as if the tool definition in BOBCAM has a max length of 2"
« Reply #5 on: July 21, 2013, 04:36:30 PM »
Yes, I thought of that. However I couldn't find the offset value. I see the offset register selection. Maybe it's just user error. Do you know where I can adjust tool length offset? Thanks
PS: I got everything running and working great using FeatureCam. Once you go through the learning curve with FC, it works very well IMO.
« Reply #6 on: July 22, 2013, 03:50:18 AM »
Will BobCAD not be of help for you?
« Reply #7 on: July 24, 2013, 04:34:17 PM »
Can you define your Tool Holder/Arbour combination to effectively extend the length of the tool and still give appropriate holder/arbour geometry at the top?
I know it's a common workaround when using T-Slot cutters to undercut to define them as a disc cutter on a long holder,
Nick
Edit -  I've just defined a 1/2" tool with 1/2" holder and 1/2" arbour with overall length of 5" so this looks like a possible workaround ;-)
« Last Edit: July 24, 2013, 04:50:52 PM by magicniner »
