Hello Guest it is November 23, 2026, 06:05:03 PM
Author Topic: Jogging off switches  (Read 9274 times)
« on: July 19, 2013, 12:17:54 AM »
Can any one help
I have built a small cnc router all good.
Home swithes have been wired in a daisy chain fashion and all work well.
Problem if I hit a stop either by jogging or during a program run I cannot get off the swith without shutting the motors down and manually winding off the switch.
Is there a setting in mach3 that allows me to jog off the switch without turning the thing off?
Many thanks
Adrian
Re: Jogging off switches
« Reply #1 on: July 19, 2013, 12:54:28 AM »
Settings page, enable Auto Limit Override. Tick this and it will allow you to jog off the stops but make sure you move in the correct direction. Jim
« Reply #2 on: July 19, 2013, 01:47:15 AM »
Many thanks will give it a try
