Hello Guest it is November 14, 2026, 03:15:46 AM
Author Topic: How to install a wizard?  (Read 16464 times)
« on: July 17, 2013, 02:00:35 PM »
This week's Mach turn bucket list is down to one thing.  Got threading going fairly well and parting-off working great thanks to Hood's tutelage about G94/G95.  #3 on the list is peck drilling.
I ran across this post http://www.machsupport.com/forum/index.php/topic,16533.0.html and the wizard contained therein looks like it will work for me.  I downloaded & unzipped the files but danged if I know how to install them.  Anyone have any advice on how to make it work?
Milton from Tennessee ya'll.
Re: How to install a wizard?
« Reply #1 on: July 17, 2013, 03:38:01 PM »
place them in the Turn Addons folder.
« Reply #2 on: July 17, 2013, 04:36:03 PM »
Thanks!  Must've done something wrong though, I get "error ->.set file missing"
« Reply #3 on: July 17, 2013, 05:04:20 PM »
Did you possibly forget to unzip it first?
« Reply #4 on: July 17, 2013, 05:32:49 PM »
I've been known to be in hurry at times but I've never forgotten to unzip first.:D
The files don't have a .zip extension on them so I think they were successfully extracted.  I'm going to wait 'til I get home from work & try it again on the PC that's actually connected to the lathe.  I have the same version of mach installed here at work with the .xml from the shop PC so it should work but who knows, something may be corrupted.
« Reply #5 on: July 17, 2013, 06:47:09 PM »
 :D
When I downloaded the add on, it was definitely a zip file so please check that as it may be the issue.
« Reply #6 on: July 17, 2013, 08:01:29 PM »
Thanks Dave, the downloaded files were definitely zipped & I had extracted them OK.  The problem was there were too many folders.  Once I figured out which folder was needed, I deleted what wasn't needed & dragged the correct one over to AddOns.  Then it worked fine.
Thanks again!
« Reply #7 on: July 18, 2013, 03:57:11 AM »
Not sure what you mean about too many folders. Yesterday when you had this issue, I downloaded it myself, extracted it, and put it in the add-ons folder, and it worked perfectly.
Wonder what you're getting with too many folders?
« Reply #8 on: July 18, 2013, 08:43:16 AM »
Probably something I was doing wrong but if I remember right it created a folder named Drill Wizard 1.3 with a subfolder Turn Add Ons and inside that was the folder I needed Drilling(Lathe)  The first couple of tries I drug the whole Drill Wizard 1.3 folder into the TurnAddons folder in Mach & I got the error.
No biggie, it's working now, thanks! ;D
« Reply #9 on: July 18, 2013, 08:51:38 AM »
