Hello Guest it is September 12, 2026, 11:37:59 AM
Author Topic: Motor Tuning Dialog Not Appearing  (Read 11853 times)
« on: July 17, 2013, 09:19:45 AM »
I'm running an Ethernet SmoothStepper connected to a G540 and then to a Chinese 6040.
I have done the following:
1. Installed Mach3 on a Windows 7 machine and configured my settings -- all good
2. Copied the C:\Mach3 directory to a machine running Vista.
3. Start Mach3 -- jogging works, but when I try to open the motor tuning dialog, nothing appears.
What can cause the motor tuning dialog to fail to open? Are there any logs I can look at?
  Tom
  •  9,370 9,370
Re: Motor Tuning Dialog Not Appearing
« Reply #1 on: July 17, 2013, 10:40:31 AM »
Hi Tom,
Welcome to the forum.
This is not the best way to carry out an installation.
Re-install Mach3, from the installation program, onto the machine running Vista.
« Last Edit: July 17, 2013, 10:42:17 AM by Tweakie.CNC »
« Reply #2 on: July 19, 2013, 09:03:25 AM »
Thanks Tweakie -- a proper install was all that was needed.
  •  9,370 9,370
« Reply #3 on: July 19, 2013, 10:20:03 AM »
Pleased you got it sorted Tom.
Don't forget to post some pictures of the things you make with your machine in the show'n'tell section http://www.machsupport.com/forum/index.php/board,43.0.html  ;)
