Hello Guest it is October 25, 2026, 03:41:52 AM
Author Topic: Big hole where there shouldn't be any  (Read 17039 times)
Offline Hobie
  •  12 12
« on: July 07, 2013, 05:39:21 PM »
I've run into a major hole in my design.  I mean a big hole where there shouldn't be any.
Loading the G-code on my laptop system (Smooth Stepper USB, G540 controller) I can see a giant spiral at 0,0 where there shouldn't be any.
Loading the same file on my desktop system show everything correctly.  I know from experience that if I run the code on my laptop it will crash the bit into the work piece with a wide gash.
The G-code file was created using MeshCam 5 (build 37)
Any ideas as to what would cause this?
TIA,
Ken
Re: Big hole where there shouldn't be any
« Reply #1 on: July 07, 2013, 05:42:09 PM »
Your IJ mode is set wrong. Ideally your code should have a G90.1 or G91.1 at the start to tell Mach which IJ mode the code is written in, ie Absolute or Incremental.
You can set the default on General config page but as said its best done from the code itself.
Offline Hobie
  •  12 12
« Reply #2 on: July 07, 2013, 05:51:24 PM »
Pardon me for asking, but what is IJ mode?
« Reply #3 on: July 07, 2013, 05:55:12 PM »
The manual likely explains it (never read it though so maybe not ;D ) but basically it is to tell Mach how arcs are defined, ie either by absolute units or incremental units.
« Reply #4 on: July 07, 2013, 06:05:35 PM »
Too funny, ya got to love this guy!  ;D
Offline Hobie
  •  12 12
« Reply #5 on: July 07, 2013, 06:09:04 PM »
The IJ setting was my problem.
Ken
Offline Hobie
  •  12 12
« Reply #6 on: July 07, 2013, 06:10:38 PM »
He's way ahead of me and I've read a whole lot of the manual - don't remember most of it as at first it was way over my head.  It takes time to sink in.
« Reply #7 on: July 07, 2013, 06:14:44 PM »
 "We all need to educate, investigate & experience to understand what questions to ask."
Ya-Nvr-No
