Hello Guest it is November 13, 2026, 10:01:12 AM
Author Topic: MSM Turn tool tables - need a primer!  (Read 9446 times)
« on: July 05, 2013, 04:08:57 AM »
Hi All,
I am being very dim at the moment trying to setup a set of 5 interchangeable toolholders on my lathe running MSM Turn (not mill-turn) and I seem to be going around in circles.
mach3 is at 067, MSM version is 2.09
Can anyone give me a step by step sequence, ideally using the reference point as the Master tool, otherwise using a defined tool as the Master, all based on the MSM screens?
I thought that something existed but I cannot find any links.
Simon
Re: MSM Turn tool tables - need a primer!
« Reply #1 on: July 05, 2013, 06:08:06 AM »
Probably best asking on MSM Forum.
« Reply #2 on: July 05, 2013, 07:09:11 AM »
Hood,
Good point, copy/pasted there as well.
However I thought that I had seen something on the Mach3 forum...
Simon
« Reply #3 on: July 05, 2013, 07:43:10 AM »
There is a MSM section of the Mach forum, its here
http://www.machsupport.com/forum/index.php/board,85.0.html
However Dave usually says best to post on his forum for support.
