Hello Guest it is November 13, 2026, 02:10:25 PM
Author Topic: How to set up my lathe with Mach 3 Turn  (Read 9736 times)
« on: July 03, 2013, 09:03:15 AM »
Hy,  Im new Mach 3 turn user and i couldn't set up my lathe. With Jogging is Ok but to set up the axxis and to corigate the real and program's measured units its something wrong. How can I set up the origin pont for the axes?
   Someone can help ME? Pls
Re: How to set up my lathe with Mach 3 Turn
« Reply #1 on: July 03, 2013, 02:46:46 PM »
You need to calculate the steps per unit and enter that into the motor tuning window.
« Reply #2 on: July 04, 2013, 08:46:50 AM »
You could use the axis calibration feature or calculate the required steps per unit as Hood suggested, but either way confirm that they are correct.
You can find a nice units calculator in Member's Doc's.
« Last Edit: July 04, 2013, 08:49:26 AM by RICH »
