Hello
Guest
it is
November 13, 2026, 12:16:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Limit switches
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Limit switches (Read 10587 times)
Jimchi52
53
Limit switches
on:
July 02, 2013, 07:32:36 PM »
Just hooked up limit switches to my bob and when I press a limit switch I get 5 volts. I do not see anything happening in Mach 3 . I have a c33 bob, a smoothstepper usb, what am I missing?
Logged
fabhund
42
Re: Limit switches
Reply #1 on:
July 02, 2013, 11:07:18 PM »
From what I read. When you close the circuit you apply +5V to the input pin of your BOB ?
Many BOB input pins must have the input pin Grounded (0V) to work.
Best regards, Bo Andersen.
Logged
sebba
42
Re: Limit switches
Reply #2 on:
July 03, 2013, 04:23:09 AM »
should I understand your switches are NC wired and when you press them the circuit is opened
this is OK but did you set the mach3 properly? I mean "Ports & Pins/Input Signals" - port number, pin number etc?
Logged
Jimchi52
53
Re: Limit switches
Reply #3 on:
July 09, 2013, 08:11:38 AM »
Have it worked out now having trouble understanding how to set up table dimensions and machine coredinates
Logged
Fastest1
920
Houston, TX
Limit switches
Reply #4 on:
July 11, 2013, 09:43:58 AM »
There is plenty to understand there! Is there something in particular you are having an issue with or difficulty comprehending?
Logged
Print
Pages:
1
Go Up
« previous
next »
