Hello
Guest
it is
November 13, 2026, 10:15:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
parallel port card help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: parallel port card help (Read 11182 times)
nzinoz
28
on:
July 02, 2013, 04:32:25 AM »
Hi all, my old mach3 computer died so I'm now trying to use a newer comp which has no parallel port on board
I brought a no name pci parallel port card but I get a an external estop called in mach3
Has anybody got a pci parallel card that has proven to work preferable from australia
Logged
Regards
Nick
fabhund
42
Re: parallel port card help
Reply #1 on:
July 02, 2013, 01:27:01 PM »
Hi Nick.
This one works for me in a std. PC with PCI connector and WinXP
http://www.ebay.co.uk/itm/IEEE-1284-DB25-25Pin-Parallel-Port-Printer-to-PCI-I-O-Controller-Card-Adapter-2-/270829949756?pt=US_Internal_Port_Expansion_Cards&hash=item3f0eb9133c
Not from AU, but it's with free postage ;-)
Best Regards, Bo Andersen.
Logged
nzinoz
28
Reply #2 on:
July 03, 2013, 01:39:42 AM »
Thanks Bo I'll look into that one
it also appears that I have other issues with the controller
Logged
Regards
Nick
sebba
42
Reply #3 on:
July 03, 2013, 04:30:32 AM »
the default address of LPT port in mach3 is 0x378
if your adapter is properly installed goto device manager, click properties on you adapter and then check it's address at Resource tab
set it's address in mach3 and should work
Logged
nzinoz
28
Reply #4 on:
July 03, 2013, 05:36:41 AM »
Thanks sebba
checked that before posting
the adapter address was 0x378
Logged
Regards
Nick
Print
Pages:
1
Go Up
« previous
next »
