Hello Guest it is November 13, 2026, 12:14:38 PM
Author Topic: motors wont run  (Read 12526 times)
motors wont run
« on: June 30, 2013, 08:39:01 PM »
newbe help. just loaded mach3 I did the driver test it was Ok.set all the parameters. went to tune the motors.  the arrow keys change the dros for the correct axis but the steppers wont run . I lowered the speed that didn't help. I took a voltmeter measured between pins 2-18,19 20 21 22 23 I read 3.3 volts is that to low? Why didn't that change when I pressed different arrow keys
Re: motors wont run
« Reply #1 on: June 30, 2013, 08:44:32 PM »
Newbie questions. I just loaded Mach 3, tried to set the steppers they wont run. I did the driver test it was fine. I turned down the speeds on the motors that didn't help. I checked the port #1 number it was fine. Is there any way to read the voltage from the port? What pin numbers and what should the voltage be. thank you
Offline jve
  •  128 128
Re: motors wont run
« Reply #2 on: June 30, 2013, 10:31:16 PM »
you have to give more info what kind of breakout board are you using ?
Re: motors wont run
« Reply #3 on: July 01, 2013, 05:50:25 AM »
Post your xml file that you used.
To attach:
Open Mach as normal and look lower right at the profile name.
 Close Mach then look in the mach3 folder on your computer for a file of that name with a .xml file extension.
 Right click and copy then go to your desktop and paste it then rename to something like JVE1.xml.
Then on the reply page use the additional options button to browse to your desktop and attach the renamed file.
« Last Edit: July 01, 2013, 05:56:07 AM by RICH »
Re: motors wont run
« Reply #4 on: July 02, 2013, 06:47:58 PM »
jve,
Using C10-Bidirectional Breakout Board Rev. 10 from CNC4PC.  Thanks.
Re: motors wont run
« Reply #5 on: July 02, 2013, 06:57:17 PM »
Rich,
Thank you very much.  The file is attached.
Re: motors wont run
« Reply #6 on: July 10, 2013, 05:24:29 AM »
Jeffrey,
Is your PP  3.5 or 5.5 volt? Some are single voltage and some are dual and usualy there is a jumper to set the dual
ones to high or low voltage. So set it for 5.5 volts. You should see a swing in voltage from 5.0 to say .8 volts on change of direction. Also set / tick the active low or high in Ports ad Pins / Motor Outputs for what's required by the BOB.
