Hello Guest it is November 18, 2026, 06:04:35 PM
Author Topic: Multipass Wizard for Mach Turn  (Read 9393 times)
« on: June 30, 2013, 02:43:17 PM »
Hi, i am new to Mach3, i have used it for a while and i like it.
But, when turning i would like to have the posibility to have multipasses.
Is there anyway to do this in Mach3 Turn.
i tried to make the G code in mach3 mill, and use the Multipass file converter, but in Mach Turn i get a Wrong Preview of the job. ?
Is there another way to do this
Børge
Re: Multipass Wizard for Mach Turn
« Reply #1 on: July 01, 2013, 06:04:41 AM »
Borge,
There are programs to generate code for the lathe.
Try using Lazyturn ( free and manual is in Member's Doc's) to generate the code and use the lathe screen.
There are also turn wizards for individual operations.
If you are going to do a lot of lathe work consider a program such as Dolphin for the lathe.
« Reply #2 on: July 01, 2013, 11:50:34 AM »
Thanks Rich, will look into that.
Børge
« Reply #3 on: July 01, 2013, 02:41:09 PM »
The multipass wizard COULD be adapted to turn. Brian would have to do it or give permission to access the code as the wizard is locked as to code modifications.
