Hello Guest it is November 13, 2026, 11:33:19 AM
Author Topic: Tool Path Display  (Read 9499 times)
Tool Path Display
« on: June 29, 2013, 02:15:40 PM »
Hello Group,Art;
Still new to Mach3 and was going over some early tutorials and came across one that showed the tool as a green conical shaped Icon tracing out the path of the material being cut ( The famous RoadRunner) The Icon was also spinning around when the spindle was turned on in Mach3 ( I really liked the animation)
I'm working on a licensed mach3 on my laptop that is not wired up to my cnc , I use this computer to design projects and run tests before loading the G-code file on the computer that controls my cnc.
Also, my spindle (Router) is not controlled by Mach3.
Could this be the reason I can't get the Icon to show on Mach3 when running a test program and or the fact that my spindle is not controlled by Mach3?
Thanking everyone in advance
Jerry
Re: Tool Path Display
« Reply #1 on: June 29, 2013, 04:02:21 PM »
Its not in Mach any more.
« Reply #2 on: June 29, 2013, 05:59:20 PM »
Thanks Hood
Too Bad
Jerry
