Hello Guest it is November 13, 2026, 09:38:44 AM
Author Topic: flying saw by mach3  (Read 13752 times)
flying saw by mach3
« on: June 29, 2013, 07:51:44 AM »
Is there any possibility to control flying saw by using mach3 brains?
Link for ex. here http://www.youtube.com/watch?feature=endscreen&v=v_DaiTfZ8oc&NR=1
Thanks in advance....
Offline jve
  •  128 128
Re: flying saw by mach3
« Reply #1 on: June 29, 2013, 08:19:27 AM »
yes it can ;)
« Reply #2 on: June 29, 2013, 08:52:51 AM »
There is 2 (X and Y) axis and 1 main axis(as a spindle).
There is an encoder to synchronize Y axis speed and main axis.
X  is the cutting axis.
Is there any road map to realize it? Any ideas...
Offline jve
  •  128 128
« Reply #3 on: June 29, 2013, 09:16:25 AM »
where you from ?
« Reply #4 on: June 29, 2013, 10:53:48 AM »
Any ideas...
from Istanbul
« Reply #5 on: June 29, 2013, 02:20:00 PM »
No you cannot do it LIKE they do it as MAch3 cannot sync an axis to an encoder under gcode control.  I only see 2 axis, the cutting axis and the traveling axis.
It could be done but will NOT be as efficent or as smooth as what you showed as an example. Also the motion will have to be programmed as Gcode.
Just a thought, (;-) TP
« Reply #6 on: July 03, 2013, 09:41:11 AM »
Thanks for your replies...
