Hello Guest it is November 13, 2026, 03:17:06 PM
Author Topic: csmio  (Read 54106 times)
Re: csmio
« Reply #30 on: June 29, 2013, 05:48:11 AM »
I assume you are using the analogue outputs to control the spindle ? If yes then you do not have the modbus section enabled, see pic below. You should have that enabled and the values should be 64 and 4095 as per my earlier screenshot.
Let me know  if that helps.
Offline jve
  •  128 128
Re: csmio
« Reply #31 on: June 29, 2013, 06:00:01 AM »
I made that enabled but it keep making same think no luck !!!
Offline jve
  •  128 128
Re: csmio
« Reply #32 on: June 29, 2013, 06:04:06 AM »
I post the code may be I have something missing here
Re: csmio
« Reply #33 on: June 29, 2013, 01:11:03 PM »
I loaded a standard version of Mach on the wee lathe and did a thread test and it ran just as per the video and that was with version 2.020 of the plugin.
 Cant think what could be the issue with it taking 50 seconds to pull off the thread.
Does your spindle true DRO read correctly?
Offline jve
  •  128 128
Re: csmio
« Reply #34 on: June 29, 2013, 04:07:13 PM »
yes spindle true and rpm are ok but my plugin is the latest v2,30
Re: csmio
« Reply #35 on: June 29, 2013, 06:47:21 PM »
Dont think the latest plugin will make a difference as I think it was only some plasma THC or similar that was altered.
Probably wont be at the workshop tomorrow so if I remember I will load the latest plugin and make sure but dont think it will make any difference.
Offline jve
  •  128 128
Re: csmio
« Reply #36 on: June 30, 2013, 11:05:57 AM »
what should i do then?
could it be a macro doing this?
Re: csmio
« Reply #37 on: July 01, 2013, 12:38:23 AM »
Try with the settings as the screenshot below.
Offline jve
  •  128 128
Re: csmio
« Reply #38 on: July 01, 2013, 01:31:54 AM »
ok i did have a first improvement now the spindle is not slowing down on evrey pass but i still have the issue that when it makes the pass and the tool is inside then the machine it has to go out on the x axis to clear from the tread and it is going very slow if you have team viewer i can show you exactly what it is doing
Offline jve
  •  128 128
Re: csmio
« Reply #39 on: July 01, 2013, 01:45:48 AM »
i also notice that i had set the spindle 800 rpm and now spindle true is 794 when i un tick the closed loop spindle control
