Hello Guest it is November 13, 2026, 06:43:51 PM
Author Topic: Analog inputs to mach 3  (Read 8327 times)
« on: June 17, 2013, 11:00:21 AM »
So I have a need to get a couple of analog sensors talking with mach 3.   I do not see a direct way to interface an analog sensor with mach 3 (appears to be all digital on the inputs).  Can anyone suggest a good method for interfacing?
thanks
Greg
Re: Analog inputs to mach 3
« Reply #1 on: June 17, 2013, 12:15:54 PM »
I have used both the Pokeys and a PLC in the past, also the controllers I now am using (CSMIO/IP-A, IP-S, IP-M) have  analogue I/O.
