Hello Guest it is October 25, 2026, 03:41:41 AM
Author Topic: using servos with mach3 (which breakout board)  (Read 13232 times)
« on: June 14, 2013, 05:53:53 PM »
hi, i want to convert my milltronics mill to newer controls.
i have 100v 7v/ per 1krpm servos
i have the westamp servo drives
the servos use 10v+- analog innput.  what do i use for a break out board. most use step / dir
or do i need a new servo drive that supports step / dir?
thanks
Re: using servos with mach3 (which breakout board)
« Reply #1 on: June 15, 2013, 04:09:32 AM »
You can go with new servo drives, go with a motion controller such as the DSPMC, Kflop with Kanalog cards, or one of the CS-labs products that supports analog output or try to get a set of step and direction to analog converters,
Mike
