Hello Guest it is November 22, 2026, 08:09:01 AM
Author Topic: Shuttle Pro 2 wheels won't work  (Read 15126 times)
« on: February 18, 2007, 03:33:58 AM »
Hello,
I've installed a Shuttle Pro 2, the shuttlepro.dll from the ftp site (version 1.0a) in the plugin directory, checked the box in config plugins and configured a few buttons. The buttons works fine, but the inner and outer wheels do nothing! Do i miss something? b.t.w. there is also a ShuttlePrp.m3p file. Can i load that file also?
Cheers, Andre.
Re: Shuttle Pro 2 wheels won't work
« Reply #1 on: February 18, 2007, 08:40:04 AM »
Download the ShuttlePro.m3p from the plugins page under the downloads link. After you download it, double click on it to install it. I think the FTP one is a much older version.
« Reply #2 on: February 18, 2007, 02:41:47 PM »
Thanks, that works!
Cheers, Andre.
« Reply #3 on: April 22, 2007, 03:48:10 PM »
I have this same problem. Shuttle Pro 2 buttons work fine, but the wheels don't. I tried to find the response on this prior reported problem, but I cannot seem to access the older posts. Any solutions to the unworking wheels.
Thanks.
BRH
« Reply #4 on: April 22, 2007, 10:08:54 PM »
First off don't install the stock software that came with the Shuttle Pro. It interferes with the Mach3 driver. Then download the Mach3 plug-in and install it. Here http://www.artsoftcontrols.com/PlugIns/ShuttlePro.m3p. The hardest part for me was locating the configuration page. It's located under Config... Config Plugins... then pick the yellow highlighted "CONFIG". Once I did these 3 steps mine works great. Sell the center wheel is not a great revolver wheel but the jog ring works great. I have attached a photo of my Shuttle Pro configuration.
Hope this helps.
« Reply #5 on: July 20, 2007, 11:13:43 PM »
Hi Skip,
Would you mind telling me which buttons are used and what for please. I have got the shuttlepro2 installed okay but I really like the look of your buttons and would not mind putting them on mine :).
I need to know which functions are configured and to what keys  ;D
Cheers,
« Last Edit: July 20, 2007, 11:18:14 PM by crocky »
Bob
