Hello Guest it is November 13, 2026, 11:43:48 AM
Author Topic: Driver test  (Read 17349 times)
Driver test
« on: June 08, 2013, 06:28:32 PM »
Tried using a smoothstepper but I could not get it to work so I went back to a port.I go to set the port setting but in control panel it does not show one all it has are LPT's, also I cannot run driver test
Re: Driver test
« Reply #1 on: June 08, 2013, 09:13:53 PM »
Parallel ports are LPTs.
John Champlain
Re: Driver test
« Reply #2 on: June 08, 2013, 09:16:42 PM »
What numbers do I put in for the port address all It shows is lpt3
  •  9,377 9,377
Re: Driver test
« Reply #3 on: June 09, 2013, 12:46:09 AM »
In most instances it's 0378 but check your LPT port resources page.
Re: Driver test
« Reply #4 on: June 09, 2013, 07:41:41 AM »
I went back to the smoothstepper usb because I am running windows 7 64 bit. It seems to be working but nothing moves except the numbers on the screen, I cannot get rid of the estop, I dont even have one operating yet
Re: Driver test
« Reply #5 on: June 09, 2013, 11:23:46 AM »
If you do not have an E-Stop connected (not the best idea but.... ) you will have to change the active state of the E-Stop input in Ports and Pins, Inputs page.
However your above statement confuses me as you say the numbers  are moving but you say you cant get rid of the E-Stop. If you cant get Mach out of reset then the axis should not be jogging and DROs should not be changing.
Re: Driver test
« Reply #6 on: June 09, 2013, 12:38:27 PM »
My mistake no numbers moving and try getting rid of the estop but nothing works
Re: Driver test
« Reply #7 on: June 10, 2013, 03:01:08 AM »
Did you change the active state of the E-Stop entry in Ports and Pins, Inputs?
Re: Driver test
« Reply #8 on: June 10, 2013, 05:32:49 AM »
Yes I did clicked it off and it is set to 10
Re: Driver test
« Reply #9 on: June 10, 2013, 06:12:34 AM »
I set the ports and pins to 1 and 11 and active low and now it works, but I do not have an estop hooked up yet
