Hello
Guest
it is
November 13, 2026, 11:28:54 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Driver test
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Driver test (Read 17345 times)
Jimchi52
53
Driver test
on:
June 08, 2013, 06:28:32 PM »
Tried using a smoothstepper but I could not get it to work so I went back to a port.I go to set the port setting but in control panel it does not show one all it has are LPT's, also I cannot run driver test
Logged
Picengraver
343
Re: Driver test
Reply #1 on:
June 08, 2013, 09:13:53 PM »
Parallel ports are LPTs.
John Champlain
Logged
www.picengrave.com
Jimchi52
53
Re: Driver test
Reply #2 on:
June 08, 2013, 09:16:42 PM »
What numbers do I put in for the port address all It shows is lpt3
Logged
Tweakie.CNC
9,377
Super Kitty
Re: Driver test
Reply #3 on:
June 09, 2013, 12:46:09 AM »
In most instances it's 0378 but check your LPT port resources page.
Logged
Jimchi52
53
Re: Driver test
Reply #4 on:
June 09, 2013, 07:41:41 AM »
I went back to the smoothstepper usb because I am running windows 7 64 bit. It seems to be working but nothing moves except the numbers on the screen, I cannot get rid of the estop, I dont even have one operating yet
Logged
Carnoustie, Scotland
Re: Driver test
Reply #5 on:
June 09, 2013, 11:23:46 AM »
If you do not have an E-Stop connected (not the best idea but.... ) you will have to change the active state of the E-Stop input in Ports and Pins, Inputs page.
However your above statement confuses me as you say the numbers are moving but you say you cant get rid of the E-Stop. If you cant get Mach out of reset then the axis should not be jogging and DROs should not be changing.
Logged
Jimchi52
53
Re: Driver test
Reply #6 on:
June 09, 2013, 12:38:27 PM »
My mistake no numbers moving and try getting rid of the estop but nothing works
Logged
Re: Driver test
Reply #7 on:
June 10, 2013, 03:01:08 AM »
Did you change the active state of the E-Stop entry in Ports and Pins, Inputs?
Logged
Jimchi52
53
Re: Driver test
Reply #8 on:
June 10, 2013, 05:32:49 AM »
Yes I did clicked it off and it is set to 10
Logged
Jimchi52
53
Re: Driver test
Reply #9 on:
June 10, 2013, 06:12:34 AM »
I set the ports and pins to 1 and 11 and active low and now it works, but I do not have an estop hooked up yet
Logged
Print
Pages:
1
Go Up
« previous
next »
