Hello Guest it is November 13, 2026, 03:16:38 PM
Author Topic: Problems with screen size after update  (Read 10755 times)
« on: June 05, 2013, 02:44:06 PM »
I just updated from 3.042.020 to 3.043.066 and the Mach screen no longer fills my monitor.  I am using the same XML that I was using with the old version and Auto Screen Enlarge is checked on the General Config page, but the Mach screen is no longer filling my monitor screen.  I copied the Mach folder before the update and if I run the old version of Mach, the auto enlarge works.   Can anyone help?
Bill (the Cat) Shubert
Re: Problems with screen size after update
« Reply #1 on: June 05, 2013, 03:57:50 PM »
Did you close and restart Mach3?
« Reply #2 on: June 05, 2013, 04:07:40 PM »
I closed and restarted Mach3 and I even rebooted the computer.  No luck.
« Reply #3 on: June 05, 2013, 04:25:06 PM »
Do you have Mach3 maximized?
« Reply #4 on: June 05, 2013, 04:51:45 PM »
That was it.  I had tried maximizing before and it simply expanded the window but the Mach screen itself stayed the same size....so I had always switched it back.  This time I closed Mach with the window maximized (even though the Mach screen was still undersized) and then restarted..... it now fills the screen.
Thanks for making me think!
