Hello Guest it is November 13, 2026, 02:15:31 PM
Author Topic: BP Ez-path lathe  (Read 9057 times)
BP Ez-path lathe
« on: June 05, 2013, 02:16:58 PM »
I recently bought a Bridgeport Ez-Path lathe 1995 edition with a EMI (Electro-Mechanical Integrators) Retrofit package I would like to know if anyone knows, seen or heard of using mach3 on one of these machines.
The way this retrofit works is EMI replaced the original computer with a more modern one but kept all BP controller boards ( Vintage ISA slots and all ) I'm fairly sure I can run windows on it just wondering if Mach could talk to these old boards i believe it's called a BMDC (I could be wrong)
For the record the machine works fine but the BP software on it isn't what I'm used to. I have a Series Two BP with a Mach 3 package and I'm very happy with it. (And very used to how it works)
Thanks!
Re: BP Ez-path lathe
« Reply #1 on: June 06, 2013, 01:48:55 AM »
You will not be able to use Mach with the existing boards I am afraid, well you likely could if you managed to write a plugin but that is likely not an option for the vast majority of people.
