Hello
Guest
it is
November 26, 2026, 09:15:45 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Scale is off by /10
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Scale is off by /10 (Read 27456 times)
Carnoustie, Scotland
Re: Scale is off by /10
Reply #10 on:
June 03, 2013, 05:13:52 PM »
So you can MDI a 1inch move and its ok but you cant jog without a problem?
Can you attach your xml and I will have a look at it.
Jerry In Maine
39
Reply #11 on:
June 03, 2013, 05:39:10 PM »
Trying but having trouble with the attachment....might show up twice...will wait a bit and try again.
Jerry In Maine
39
Reply #12 on:
June 03, 2013, 05:40:58 PM »
Reply #13 on:
June 04, 2013, 01:58:24 AM »
Ok can you please answer the questions I asked above regarding the way your axis is set up, pitch etc.
Also what version of Mach3 are you using?
Reason I am asking is your steps per unit do not seem right, they are very course.
Jerry In Maine
39
Reply #14 on:
June 04, 2013, 04:47:52 AM »
I might have it right now...
Noticed that the onscreen scales were off from measured distances by. Factor of 10. In desperation I multiplied the steps per unit by 10 and the results were close.
If it is right now I can't figure way the "set steps per unit" (under SETTINGS) would give me coarse numbers, because as mentioned I could ak for one inch and get exactly that.
Let me do some more checks and if its still wrong ill get you that ino you asked for.
Jerry In Maine
39
Reply #15 on:
June 04, 2013, 10:40:37 AM »
Steps per inch were off by x10. Still can't figure how I was getting the right amount of movement under MDI unless I had some other setting right or wrong...both X and Y steps per inch are now at 1422, and to get that I looked up the math. In hindsight I should have done that first - lesson learned for the future. I did increase the step pulse.
Thanks for your patience and help.
Reply #16 on:
June 04, 2013, 12:21:13 PM »
The xml you attached earlier had 34 for X and Y steps per unit so it must have been the wrong xml.
Jerry In Maine
39
Reply #17 on:
June 04, 2013, 12:34:28 PM »
Don't understand that either....they're at 1422 now.
Seems lots of stuff lately has been out of my range of comprehension.
Again, thanks. I like getting help from folks far off because they can't reach over and slap me for being ignorant.
Reply #18 on:
June 04, 2013, 01:39:40 PM »
As long as its working thats all that matters
Print
Pages:
1
2
Go Up
« previous
next »
