Hello Guest it is November 26, 2026, 09:15:44 PM
Author Topic: Scale is off by /10  (Read 27456 times)
Re: Scale is off by /10
« Reply #10 on: June 03, 2013, 05:13:52 PM »
So you can MDI a 1inch move and its ok but you cant jog without a problem?
Can you attach your xml and I will have a look at it.
« Reply #11 on: June 03, 2013, 05:39:10 PM »
Trying but having trouble with the attachment....might show up twice...will wait a bit and try again.
« Reply #12 on: June 03, 2013, 05:40:58 PM »
« Reply #13 on: June 04, 2013, 01:58:24 AM »
Ok can you please answer the questions I asked above regarding the way your axis is set up, pitch etc.
Also what version of Mach3 are you using?
Reason I am asking is your steps per unit do not seem right, they are very course.
« Reply #14 on: June 04, 2013, 04:47:52 AM »
I might have it right now...
Noticed that the onscreen scales were off from measured distances by. Factor of 10. In desperation I multiplied the steps per unit by 10 and the results were close.
If it is right now I can't figure way the "set steps per unit" (under SETTINGS) would give me coarse numbers, because as mentioned I could ak for one inch and get exactly that.
Let me do some more checks and if its still wrong ill get you that ino you asked for.
« Reply #15 on: June 04, 2013, 10:40:37 AM »
Steps per inch were off by x10. Still can't figure how I was getting the right amount of movement under MDI unless I had some other setting right or wrong...both X and Y steps per inch are now at 1422, and to get that I looked up the math.  In hindsight I should have done that first - lesson learned for the future. I did increase the step pulse.
Thanks for your patience and help.
« Reply #16 on: June 04, 2013, 12:21:13 PM »
The xml you attached earlier had 34 for X and Y steps per unit so it must have been the wrong xml.
« Reply #17 on: June 04, 2013, 12:34:28 PM »
Don't understand that either....they're at 1422 now.
Seems lots of stuff lately has been out of my range of comprehension.
Again, thanks. I like getting help from folks far off because they can't reach over and slap me for being ignorant.  ;)
« Reply #18 on: June 04, 2013, 01:39:40 PM »
As long as its working thats all that matters :)
