Hello Guest it is November 13, 2026, 02:46:23 PM
Author Topic: Tempurature  (Read 10688 times)
Tempurature
« on: May 31, 2013, 08:25:13 AM »
Can Mach read and/or display tempurature? If so, how.
Re: Tempurature
« Reply #1 on: May 31, 2013, 08:38:11 AM »
It depends what your temp sensors signal is, for example you can input analogue voltages with certain devices, I use a PLC with analogue inputs on some machines and on others I can take them in directly o the controller (CSMIO/IP-A ,  IP-S and IP-M)
The pokeys can also be used to get analogue inputs into Mach but it is just 0-3v (or possibly 0 to 5v) where the other ones I mentioned above are 0-10v.
Once you have that signal in Mach you can do what you want via a Brain or the Macropump.
Re: Tempurature
« Reply #2 on: May 31, 2013, 09:16:24 AM »
So the hardware is needed for A/D conversion?
Re: Tempurature
« Reply #3 on: May 31, 2013, 09:46:03 AM »
Yes.
