Hello Guest it is November 24, 2026, 09:13:24 AM
Author Topic: IBM T60 Laptop Compatibility  (Read 10982 times)
« on: February 16, 2007, 04:22:57 AM »
Hi All,
I've read many post regarding laptop incompatibility with Mach but...
I would like to know if the following configuration would work with Mach3
IBM Thinkpad T60
Intel Core Duo Processor: T2400 1.83GHz
RAM: 1GB DDR2
Hitachi 60 GB Serial ATA
Video Card: Intel 950 Graphics card
Many thanx,
Jonathan
Re: IBM T60 Laptop Compatibility
« Reply #1 on: February 16, 2007, 02:07:04 PM »
Download Mach and run the drive test, if it looks good then the chances are it will work fine.
BTW I presume there is a parallel port in the laptop or are you planning on using a pod or Galil or ........?.
« Reply #2 on: February 16, 2007, 02:21:23 PM »
I already have Mach3 running on my ThinkPad T40 (Pentium M 1.3GHz).  It's dog slow  with drivertest reading somewhere at 800Hz no where near the 25000 desire.
I'm just hopping someone Core Duo is running Mach3 can chime in before I put $1K down on the laptop.
« Reply #3 on: February 16, 2007, 02:22:47 PM »
Ahhhh sorry, thought you already had it. Can you not build yourself a cheap desktop?
