Hello Guest it is October 21, 2026, 06:09:11 AM
Author Topic: Getting small movements which not supposet to..  (Read 82782 times)
Re: Getting small movements which not supposet to..
« Reply #50 on: July 05, 2013, 04:01:01 PM »
Hello Hood,
                I took some photos and videos of my gantry mill, the controller has 1 x C10 board + 6 SSR:
Video:
http://s1204.photobucket.com/user/cncfreakcncfreak/media/BVB25L%20cnc%20conversion/GantryMillMach3_zpsa9b556be.mp4.html
« Reply #51 on: July 05, 2013, 04:21:24 PM »
Looks like a big solid machine :)
One thing I would check up on is that you can mount that servo drive horizontally, most I have seen said they must be mounted vertically to get proper airflow.
« Reply #52 on: July 05, 2013, 09:51:35 PM »
The gantry was purchased as used about 2 years ago, is a 2.8m length, 1.8m wide, small machine compare to my neighbour's 5m long gantry. This machine only for facing, it is not suitable for positioning error is too large (lead screw).
Ill add a fan at the top of that amp some day.
I'm waiting for my new machine cover from Defender for the lathe:
http://www.machine-cover.com/products.htm
then will proceed encoder installation.
« Reply #53 on: August 12, 2013, 01:25:20 AM »
Hello I'm back, just had the X saddle drilled 6 threaded holes 3 each side for securing the cover.
« Reply #54 on: August 14, 2013, 10:03:40 AM »
Had the Index Pulse Interrupter Disc made:
will continue with the sensor holder after I come back from holidays!
« Reply #55 on: September 08, 2013, 10:30:44 PM »
Add a sensor holder:
« Reply #56 on: September 17, 2013, 03:00:48 AM »
Ok, Sensor installed, EE-SPX406: http://www.ia.omron.com/data_pdf/data_sheet/ee-spx-w_dsheet_csm474.pdf
Wire: brown = 24V, Black = Index signal, Blue = 0V
I set the Index Input to pin 10 port 1, how do I determine if there's signal coming in to Pin10? Mach 3 turn no Diagnosis tab?
« Reply #57 on: September 17, 2013, 04:33:31 AM »
Check the wire connection, the Index terminal was connected wrong and has been corrected and previously the 0v wire is not wired to BOB's com (gnd), Index pin is flashin in Diagnosis.
http://s1204.photobucket.com/user/cncfreakcncfreak/media/BVB25L%20cnc%20conversion/IMG_3953_zps859e6a27.mp4.html
« Reply #58 on: October 04, 2013, 11:18:50 AM »
Ok, I have been thinking a lot whether to use my servo drive in speed control mode or position control mode for spindle?
If I use speed control mode then I can use my spare C6 from cnc4pc to feed 0-10VDC to MRJ2S drive like this:
