Hello Guest it is October 22, 2026, 07:22:49 PM
Author Topic: COMO CONFIGURAR MACH3 CON ESTA INTERFACE  (Read 30001 times)
« on: May 25, 2013, 12:38:43 PM »
  •  9,374 9,374
Re: COMO CONFIGURAR MACH3 CON ESTA INTERFACE
« Reply #1 on: May 27, 2013, 04:45:13 AM »
¿Que es (Fabricante / modelo)
« Reply #2 on: May 27, 2013, 01:05:24 PM »
desconozco los datos de esa placa en particular, pero se ve muy sencilla, fijate que debe tener los N° de P1, P2, P3, etc etc,
esos son los pines que deberas setear en el MACH, normalmente del P2  al P9 conectaras tus drivers de motores, en P10, P11, P12, P13, los microswitch o boton de Emergencia o Stop, habria que ver el rel{e a que Pin está asignado, pero podes probar seteando el P14...
Suerte y despues nos cuentas..
« Reply #3 on: May 27, 2013, 01:29:54 PM »
« Reply #4 on: October 12, 2013, 04:20:05 PM »
CNC  Breakout Board adapter for PC Stepper Motor Driver
CNC interface board, you can make your computer into a powerful CNC controller!
5 axis Breakout board
Compatible: KCAM4 MACH EMC2
Built in DB25 male connector
It is with 4-wire limit switch to insure our safty movement
It is with relay port to contro the cnc spindle
Working voltage is 5VDC and support with MACH3,EMC2,KCAM4 software
25-pin parallel port control is defined as follows:
DB25 control pin (PIN)    The pin of the drive board   Comment
1   STEPB   B(Fifth axis)pulse signal
2   STEPX   X(First axis) pulse signal
3   DIRX   X(First axis) direction of the signal
4   STEPY   Y(Secondaxis)pulse signal
5   DIRY   Y(Second axis)direction of the signal
6   STEPZ   Z(Third axis) pulse signal
7   DIRZ   Z(Third axis) direction of the signal
8   STEPA   A(Fourth axis) pulse signal
9   DIRA   A(Fourth axis) direction of the signal
10   LIMIT-1   Limit input interface 1
11   LIMIT-2   Limit input interface 2
12   LIMIT-3   Limit input interface 3
13   LIMIT-4   Limit input interface 4
14   DIRB   B(Fifth axis) direction of the signal
15   Vacant
16   RLY   Relay control
17   EN   All axis enable
18-25   GND   GND
