Hello Guest it is November 13, 2026, 10:11:47 AM
Author Topic: Dimensions twice what they should be  (Read 9851 times)
« on: May 22, 2013, 05:13:13 PM »
I have calibrated all axes and they measure what I put into the software.
However, when running a simple rectangle program the dimensions are twice what they should be.
Any suggestions as to how to correct this.\?
Re: Dimensions twice what they should be
« Reply #1 on: May 22, 2013, 05:37:25 PM »
You probably need to turn the velocity and accel way down from what they are now if your trying to use the auto calibrate.  Best to do the math to arrive at your steps per for this reason.  If you skip steps while doing the auto calibrate or have backlash that isn't taken up auto calibrate will not take that into consideration.
« Reply #2 on: May 22, 2013, 06:38:41 PM »
Thanks Bret.  Will give it a try
« Reply #3 on: May 27, 2013, 02:11:33 AM »
Alos make sure that the scaling DROs are set to 1.
